hunas2127
Junior Member level 2
As shown in the figure above, I connected four transistors in parallel at the output stage to increase the output power.
ZLOPT is the optimum load impedance obtained from a load-pull simulation of a single transistor.
I'm planning to match the impedance using the method shown in the diagram below.
- Should I match 50 ohms to ZLOPT? Or since there are four transistors connected in parallel, should I match 50 ohms to ZLOPT/4?
- I understand that I can use a series inductor for matching,
but I don't know how to convert this into a series transmission line.
For example, if I have a 100 pH inductor, how can I replace this with an equivalent transmission line?
