how to pause a hspice simulation?
Robert Qi
Shenzhen, P.R China
hspice pause
Dear All,
Anyone knows how to pause a hspice simulation?
Also, I sometimes need pause a simultion, shut down the machine, restart the machine several hours later, then go on the paused simulation from the break point. Is it possible?
Robert
you can save all operation point in a file, and load this file when continue run.
please search .save and .load in Hspice manual.
good luck!
saveoperation and then load this file
Dear All,
I browsed Hspice manual for .save and .load commands, and tried them.
But the commands can only let the simulation skip OP calculation step. Simulation starts from the zero time point again. But I expect it start from the break point.
Anyone can tell the details?
Robert
As I know, hspice doesn't has the function. But hsim has, refer to .store and .restore statement in hsim manual.
Hspice doesn't support this feature.
Btw, is there any setting that hspice can abort automatically in case the result file is too large, ie 2G?
As per my knowledge, hspice don't have that option. it always starts from zero time. It gives a pop up window if the file size is too large than the available disk size.
