Register Log in
How to parse an array C++?
FboDigit
Member level 1
Canada
Hi all, I used to be good at programming in C but I didn't pratice since a lottt of years so I need a little ramp up
I want to parse an array but I am not able to do it and I feel really noob !!
[B]IN THE .h[/B]
   void Test_I2C(int);
[B]IN THE .CPP[/B]
int *csv_array[5]; //is it good ???
	int i;
	for(i=0 ; i<sizeof(csv_array)/sizeof(*csv_array);i++) //this is good
		useless code for the example
MyFunct(csv_array[i]); //is it good ?
void MyFunct(.......) ///what to put here
   var = csv_array[1];
Also if you have a better//easyer way to do it (with pointer or struct) I would really appreciate the help
Please help !!!
btbass
Advanced Member level 5
Oberon
Re: Parsing an array C++
int *csv_array[5]; //This is an array of pointers to ints.
for(i = 0; i < 5; i++)
MyFunct(csv_array); //The argument of the call is a pointer to an int
void MyFunct(int *ptr) ///what to put here, an int pointer
int value;
value = *ptr;
FboDigit
Member level 1
Canada
Hi btbass !
Thx for the answer but I got 2 error while doind this.
The first compilation error is : 'main::my_funct' : cannot convert parameter 1 from 'int *' to 'int'
and the second is error C2511: 'void main::my_funct(int *)' : overloaded member function not found in 'main'
I really don't understand the meaning of those warnings
Regards
EDIT :Is there a way to use a specific memory space with *ptr ?
btbass
Oberon
It sounds like you have defined the function with an int as the argument and not an int pointer.
void my_funct( ? )
Are you sure you need an array of pointers to int?
Why not just an array of int?
FboDigit
Member level 1
Canada
Hi btbass
Of course only an array of int would be enough!
I have done this:
void my_funct(int[]);
void main
int csv_array[5];
for(...){
my_funct(csv_array[]);  [U]// Line 69 [/U]
void my_funct(csv_array[5])
But the compiler say
'error C2059: syntax error : ']' on the line 69
I don't want to lose any more time on this I only want to parse an array as a variable.
Thanks for your help
btbass
Oberon
my_funct(&csv_array[0]); /* pointer to start of array */
void my_funct(int *array)
int a, b;
a = array[0];
b = array[1];
FboDigit
Member level 1
Canada
Thanks you btbass it is working !!!!
Toggle Sidebar
