How to overcome setup time violation?
cutykat
Newbie level 2
I would like to know what needs to be done when there is a setup time violation.
How can it be set right ?
Thanks,
time violation
I might be able to help. But, if you could be more specific about the problem you are seeing and where in the design phase you are in, it would allow me to provide a better, focused answer.
fixing the setup time violation
Set up time violation,
Use High effort option in the synthesis tool, if it is not helpful then, try to reduce the input delay for the flipflop by appropriate coding and design.
regards
Raghu
setup time violations
last chance is reducing the clock frequency.
how setup time violation
If you are going to reduce the clock frequency instead of fixing the input delay,
then watch out your hold time first.
set up time violations
This is a kind of broad question.
If area is not a concern then you can use a driving cell with high driving capacity.
Most of the designing tools results are specific to the coding style. Somtimes changing coding style may achieve better timing.
Could you tell me the exact problem:?:
setup timing violations
Proper Constrainig depending on the Tool might help or chage the design if the currebt frequency has to be met
ff setup high violation
First let the tools synthesize the design with higher effort, if it doesn't work you'll have to go back to modify your RTL code. To break the worst path into 2 parts by inserting a FF in the middle, or, just latch some signal before using it if the it's ok with your logic.
setup timing voilation
you may ask your backend team also, sometimes they can help you fix the violations on the layout side
how to fix setup time violation
it depends on which design phase you are in. In pre layout phase, synthesis tool running with a high effort may resolve the prolbem, logic change can do it too.
If postlayout, you may need to move cells, sizing up cells.
