How to obtain the basic parameters of P/N mos for manual calculation?
aaronwu
Newbie level 5
now I have P/N mos model(BSIM49), as we know, we need manual calculation to solve 80% op design issue, but how to obtain the basic parameters of P/N mos for manual calculation? such as K',Vt,lamda .etc. Thanks a lot!
op design question
You can find vth in the model. It is vth0.
You can also find tox,u to calculate K. Maybe you can find lamda by simulatingI/V curve.
op design question
It seems just a problem of figuring out the process parameters from the foundry's PDKs.
Added after 48 seconds:
You can look up the Parameters according to some textbook
op design question
Thanks leo_o2 and DZC! I only have model file, no textbooks. My concern is that if I find vth0, tox,u from the model, are these parameters enough accurate for manual calculation results?
Added after 1 minutes:
I want to know original designer how to figure out these parameters or how to solve this problem. Thanks a lot!
op design question
aaronwu,
Here are some tricks to findout the Vth of device
1. Connect your NMOS device in diode connected fashion
2. Select W=10um and L= Lmin for your technology / 0.5um
3. Now apply Vdd = VDD given in your technology
across the Drain and Source so that Vgs=Vds
4. Now run .Op analysis
5. Check spice log file .. in case of hspice list file ..
you will get all its parameters ..
For Tox .. check the model card it is given ther ..
and if you are using MOSIS models generally all
these parameters are given for e.g.
TRANSISTOR PARAMETERS W/L N-CHANNEL P-CHANNEL UNITS
MINIMUM 0.27/0.18
Vth 0.50 -0.54 volts
SHORT 20.0/0.18
Idss 572 -277 uA/um
Vth 0.51 -0.51 volts
Vpt 4.7 -5.5 volts
WIDE 20.0/0.18
Ids0 19.9 -10.0 pA/um
LARGE 50/50
Vth 0.42 -0.41 volts
Vjbkd 3.1 -4.1 volts
Ijlk <50.0 <50.0 pA
K' (Uo*Cox/2) 169.1 -36.0 uA/V^2
source : **broken link removed**
The procedure to find lambda is given in Holburg's book ..
Raduga
op design question
thank raduga_in. it's very helpful to me.
