How to observe phase noise of VCO in hspice?
hWiUdNe
Newbie level 2
i usually do this in spectre RF. i wonder if i can do this in hspice ,
can anyone tech me that, thank you very much.
pankajdudulwar
Full Member level 2
hi,
I have used T-spice equivalent to H-spice but option of Phase noise measurement is not their.So have to calculate it theoretically with the values of current and other parameter.This theoretical values are nearly equal to the practical values only if we avoid any calculation error. Once I have verified the theoretical value with the simulation value in Cadence RFSpectre it came about nearly the same.If u need any help regarding theoretical calculation do revert back.
Pankaj
xuel
use .hvosc and .phasenoise analysis in hspice
khouly
Advanced Member level 5
EGYPT
these commands in HspiceRF option not ordinary hspice , it requires another lic
khouly
hWiUdNe
Newbie level 2
to xuel
i am using HspiceRF, i have read the command reference... i don't how to set the parameter of .phasenoise and .hobsc ... can you give me some example.. if i want see the phasenoise of LCVCO which center frequency is 2.5GHz.. what will the parameter be.. thank you very much..!
lisamoni
Junior Member level 2
Bangladesh
hi
please reply for the same ques.how can i set the parameter for .phasenoise and .hobsc.please help.
lisamoni
Bangladesh
i m using hspice 2007.03. here .phasenoise and .hosc doesnt work.is it?i simulated by this command bt there was no output
