How to multiply two numbers in VHDL?
iliya24
Member level 2
Hello.
I am a new to vhdl and as a part of my tranning i need to multiplay 2 numbers can u help me and tell my what i doing wrong?
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
ENTITY MUL IS PORT(
a,b: IN unsigned (3 downto 0);
y : OUT unsigned (7 downto 0));
END MUL ;
ARCHITECTURE Behavioral OF MUL IS
BEGIN
process (a,b)
variable temp1:unsigned(7 downto 0);
variable temp:unsigned(7 downto 0);
BEGIN
for j in 0 to 3 loop
if (b(j)='0') then
temp1:=(7 downto 0 =>'0');
else
temp1:=( j=>a(0),j+1=>a(1), j+2=>a(2),j+3=>a(3),others=>'0') ;
temp:=temp+temp1;
end if ;
end loop;
y<=temp;
end process;
END Behavioral;
iliya24
Member level 2
Re: multiply two numbers
I am re posting because i still did not get the answer how to do it without using * i need to do it only with shift and adding the bits because my numbers are binary in signed vector.
I wiil appreciated any help i have wrote an algorithm but it is not working properly (it do compile ) but result is not good.
Thx.
TrickyDicky
Advanced Member level 5
Whats wrong with the results?
For a mulitplier you need N adders where N is the number of bits.
iliya24
Member level 2
The problem is that my out is getting an unknown state. i need to do in behavioral way using for loops not with adder becouse with adders it is not efficient .
Thx.
FvM
Super Moderator
Staff member
Bochum, Germany
It seems like you don't understand the meaning of for loops in VHDL. Your code implements four adders.
iliya24
Member level 2
Ok but why is temp1 or temp after for loop is in uknoen stae?
Thx
FvM
Super Moderator
Staff member
Bochum, Germany
Because you forgot to init temp in front of the for loop;
temp := (others => '0');
iliya24
Member level 2
ok i will try it and i post u back thx
iliya24
Member level 2
Hey i tried today but this was not the issue i solved differently.
Thx.
