how to multiply two numbers in c in pic microcontroller?
engr.waqas
Full Member level 3
karachi,Pakistan
how to multiply in c
I want to multiply 819.2 with 0.0048828125 in pic using C language.
anyone can explain me this and give me C coding.
multiply microcontroller
void mult()
float f;
f=819.2*0.0048828125;
the answer is 4
I hope u had a problem with precision.
u can double or long double for more precise value.
c - multiply two numbers
actually i am taking data from a sensor whose output is 4 volt i.e analog input to pic is 4 volt .now for Vref=5 volt, i have step size of 0.0048828125 so i have multiply the output of controller's builtin A\D to 0.0048828125 to get real value that is 4.
How to do this
A\D binary output is stored in 2 registers as in PIC i.e ADRESl & ADRESH
plz help how to multiply value stored in ADRESL & ADRESH to 0.0048828125
pic c multiply
float ADnumber = (float)((int)(((int)ADRESH << 8 ) | ADRESL)) * 0.0048828125f
I think that would do it. I would check with a normal C compiler first tho. All this does is transform ADRESL & ADRESH into a 16-bit number, change that to a float, and then multiply it with your constant.
multiply number in c
Just because it doesn't have them physically doesn't mean you can't use them virtually. If you are using a C compiler of any variety (MCC18, mikroC, SourceBoost etc) it will use two 8-bit registers for a 16-bit number. That is a really basic concept btw. Trust me, I use only PICs (mainly 18F) and I use 16-bit variables all the time.
multiply in pic
That will do it because there is no need of a 16-bit register in this operation.
He is virtually implementing a 16-bit value using 2 8-bit registers.
