How to mount Windows files on Linux
nanda5001
Newbie level 5
Hi i am new to this forum
I have installed Red hat linux
I want to mount the Windows files on the linux desktop...
What's da procedure for this...
thanks
kishore
aospinas
Member level 2
partition NTFS or FAT32??
The distribuition of linux is: Fedora, CentOS, Debian, Ubuntu???
for NTFS install package:
see https://sourceforge.net/projects/linux-ntfs/
see NTFS-3G for debian
for fat32 add a /etc/fstab:
/dev/sda5 /mnt/e auto noauto,user,exec 0 0
with
/dev/sda5 : device
/mnt/e : point mount
enjoy
dwayne22
Junior Member level 2
Hi Nanda5001,
Using the NTFS package works OK, but you cannot write from Linux, only read. If you format a partition on FAT32, you can both read and write, but the filenames are only 8.3 (like DOS), which is kind of a pain...
Hughes
Advanced Member level 3
The filenames on FAT32 are not restricted to 8.3.
Some distributions support NTFS write.
qasmi
Member level 3
for help on this issue write "man mount" and "man umount"
Regards
dwayne22
Hughes, Which distributions support NTFS write? I certainly would like to have that capability...
In Fedora, and presumably also other Red Hat distributions, reading a FAT32 partition shows the 8.3 versions of the filenames, not the full ones that you see on the Windows side.
Hughes
Mandriva should support NTFS write.
The latest release of Debian (etch) should also support NTFS write.
manzion111
Newbie level 1
I'm disagree with you. You can only read but not write the NTFS.
dwayne22
Bastos,
Have you implemented this? Details please. From the website it wasn't clear how to set it up ...
bastos4321
Full Member level 5
space
dwayne22 said:
Bastos,
I have implement this in centos 4.4 and works fine.
Install fuse and then ntfs-3g.
Just follow the informations in this page: https://www.ntfs-3g.org/
Bastos
Hughes
I have ever installed Mandrake 9.2 on my PC. One day, I mount my usb disk and copy some file to one of the partition. Then I found the partition was an NTFS partition. So Mandrake 9.2 should be able write NTFS partition, right?
But I really didn't find any documents about the ability of Mandrake to write NTFS partion. And now my linux isn't mandrake, I can't prove it now.
May be it was a mistake.
RDRyan
Full Member level 2
China
Now if you kernel is 2.6x, the NTFS is support by the kernel. Update your linux kernel to 2.6x, you can solve all the problems.
