How to mount NTFS partition????
venkat3271
Full Member level 2
Chennai
ext2ntfs download
HEy,
I am using both Windows and Fedora... My windows partions are all NTFS.. How shall i mount all the drives and it should be mounted every time automatically, when i am booting Fedora... Is there any software for doing this.. PL help how to mount.. If software is available , pl give the link...
Thanks in advance..
Venkatesan.s
ntfs mounting software
access ntfs drives in rhel5
Hey,
PL.. let the software be freeware.... Mount everything is not a freeware... and has limited options for Demo version....... Whats is the command
v use for mounting NTFS drive in Fedora?????
how to mount ntfs partition in fedora
If Your kernel version of Fedora is 2.6x, it can support NTFS. otherwise you'd better to update kernel to 2.6x, and rebuild it. The 2.6x kernel is very easy to rebuild.
To mount NTFS, the command is the same with mounting ext3 drives. use as below:
mount /dev/hda0 /mnt/winC
If you want to mount NTFS automatically on booting, you can edit file /etc/fstab, add something like above command (but not the same, exactly).
    venkat3271
mount ntfs drive in fedora
Download ext2ntfs (don't remember the exactly name) is a library and is free, and then create a directory in /media and mount the partition : mount /dev/hda5 /media/directorycreated
