How to monitor the power level?
ltg
Member level 4
Power monitoring how-to?
In my project I have to monitoring 230V AC if it is disappear or it is at low level. Could any expert please give same tips? Thanks in advance!
Best Regards,
ltg
exata
Member level 1
power monitoring
If you need only to know when power is lost then you can monitor it using an opto-coupler (4N25) connected to the mains (use a large value resistor in series). If you need to know the amplitude then the better way is reading it through a small transformer.
Bagster
Member level 2
The cheapest and most easiest must be a bridge rectifier and a potential divider/comparator. A LM358 will be very cheap and you can run it from the rectified mains (within its supply limits). Configure it as a window comparator and you will be able to tell if it is hi or low.
Regards
Bagster :p
agknayak
Junior Member level 1
I think using LM358 directly would mean a series resistor to drop the 230V to a smaller voltage. This series resistor would be quite dissipative. I would actually suggest using a small transformer and then monitoring the secondary of the transformer.
Gopal.
