how to modify an element value in a subckt
zzphht
Newbie level 1
spice passing parameters to a subckt
assume circuit X1 calls subckt X2 and X2 calls two subckt X3_1 and X3_2 (X3 are the same subckt). I want to change an element value , for example a resistor value, only in X3_2 and re-run the simulation. How to do it in HSpice?
thanks.
JT
Junior Member level 1
In Spice I do this by passing parameters with the subcircuit.
This way you can change (almost) any component value in the subcircuit.
I´m not sure whether this can be done with Hspice too.
