Re: Klopfenstein Taper
This code i got from matlab website....
function Zlist=bklop(Zo,Zload,N,RdB)
% Calculate impedance list for a Klopfenstein taper
% of unit length.
% Zlist=bklop(Zo,Zload,N,RdB)
% Zo......Characteristic impedance (Ohms)
% Zload...Load impedance to match to (Ohms)
% N.......Number of sections used to approximate taper (integer)
% RdB.....Operating band ripple (dB)
% e.g. Zlist=bklop(50,100,60,-25) % Match a 100ohm load to a 50ohm line
% % with operating band ripple at -25dB.
% % Taper defined as list of 60 sections
% Note : Only valid for Zload>Zo
% Matches a load impedance Zload to a standard line impedance Zo
% using Klopfenstein taper.
% Taper profile is returned as a list of impedances, the optimum length
% for this design of taper is 0.565 lambda.
% Impedance Values
% Zo ---> [ Z1 ] [ Z2 ] .... [ ZN ] <-- Zload
% Ref D.M Pozar Microwave Engineering 2nd Ed Page 291
% N.Tucker **broken link removed** 2010
Tld=log(Zload/Zo)*0.5; % Reflection coefficient of load
Trip=10.^(RdB/20); % Lin value of ripple in operating band
A=acosh(Tld/Trip); % Intermediate variable in calculation
z=0; % Fractional distance along taper
dz=1/(N-1); % Incremental distance
Zx=zeros(1,N);
for c=1:N % Loop for impedance values along taper
M=round(z*100+25); % Number of steps for the numerical integration
PsiXA=0;
y=0;
dy=((2*z-1)/(M-2)); % Increment for numerical integration
for d=1:M % Loop for PsiXA numerical integration
PsiXA=PsiXA+besseli(1,A*sqrt(1-y.^2))/(A*sqrt(1-y.^2))*dy;
y=y+dy;
end
% Calculate impedance as a function of distance along the
% unit length transformer
LNZx=0.5*log(Zo*Zload)+(Tld/cosh(A))*(A.^2)*real(PsiXA);
Zx(1,c)=exp(LNZx);
z=z+dz;
end
Zlist=[Zo,Zx,Zload]; % Assemble the list of impedances for output
X=1:1:N; % X-axis vector for plotting
figure(10);
plot(X,(Zx),'b-',X,(Zx),'+');
xlabel('Zo Matching Section Number Zload');
ylabel('Impedance (Ohms)');
title('Transformer Impedances')
grid on;
chartname=sprintf(' Transformer Impedances ');
set(10,'name',chartname);
