sjalloq
Newbie level 3
Hi there,
I've been struggling with bringing up a power analysis flow for the last week and wanted to get some advice.
We're using VHDL RTL and ModelSim along with Design Compiler and Power Compiler.
In order to generate a backward SAIF file I am having to create a gate-level Verilog netlist because ModelSim doesn't support capturing VCD data on 2d arrays. So far I have tried two flows: one, using the Synopsys PLI with ModelSim to generate the SAIF directly and two, generating a VCD file and converting it to SAIF using vcd2saif.
Using the Synopsys PLI seemed to be very slow. A small block level netlist simulation took over 6 hours. Although it worked, using this flow on larger blocks and chip level isn't attractive.
Switching to the VCD flow to see if it was faster resulted in a huge VCD file being generated and I killed the sim. I was saving to a gzipped VCD outptus file and when I killed the sim it was already over 13GB. Note that this is a small block.
Question:
what is the correct flow for generating a VCD file from a gate-level simulation? If I capture all net toggling then am I capturing unnecessary internal library cell information that is not needed by Power Compiler that is bloating my VCD? I tried using the -nodebug switch to vlog but this prevented capture of 95% of my sequential cells.
Thanks for your help.
Added after 4 hours 16 minutes:
OK, I found my problem. User error as normal. I was using the -nodebug switch when compiling both my library and my netlist.
For those searching in future, the flow should be:
vlib library
vlog -work library -nodebug my_cell_lib/*.v my_mem_cells.v
vlog my_netlist.v
vlog my_tb.v
vsim -L library work.my_tb
And as an example of runtime, logging VCD took 2 hours while using the Synopsys PLI took 6.
Thanks.
Question:
vlib library
vlog my_netlist.v
vlog my_tb.v
Thanks.
