how to measure the total power of a cirucit using Hspice?
samuel
Full Member level 3
world
power calculation in hspice
dear, friends
i want to evaluate a circuit power using Hspice simulator, but i dont know to how to do that? anyone can tell me in details?
thank you.
sm.
hspice average current meas
Maybe you can place a ideal voltage source in the line of vdd, all current must flow cross the line. Set the ideal voltage source value=0 and you can get the whole current of the circuit. Then, you use the function power=vdd*I(total).
This method is not very simple. But I only know this. :)
hspice measure power
To print the total power:
.PRINT POWER
To print the current (or power) from VDD (usually it means the total power):
.PRINT I(VDD)
.PRINT PTOTAL=PAR('V(VDD)*I(VDD)')
Other examples:
.PRINT PTOTAL=PAR('V(VDDD)*I(VDDD)+V(VDDA)*I(VDDA)')
.PRINT PTOTAL=PAR('3.3*I(VDD)')
hspice total current
best way is to integrate supply current over a period, multiply by vdd and then divide by the period to get the power.
h**p://bwrc.eecs.berkeley.edu/classes/icdesign/ee141_f05/Project/Tips.Background.pdf
look at the hspice code on pages 3 and 4
hspice code of low power
You can use a measure comand to evaluate the average current on the time period you want, and them multiply the result bu the supply voltage;
for example:
.measure TRAN iavg AVG i(vvdd) FROM=5e-6 TO=10e-6
the result will be stored on the .lis file, someting like this:
iavg=10e-6
If you want you can also do the power calculation with hspice:
.PARAM vvddpar=3.3
.measure TRAN power PARAM='iavg*vvddpar'
hspice power measure
first of all, thank you everyone.
but i want to know which method is accuracy.
sm.
measure tran iavg
sm.
Either one.
But results may be different.
.PRINT POWER
will give you total power dissipation of the whole circuit. It is supplied by all independent voltage/current sources.
.PRINT P(VDD)
or
.PRINT PAR('VDD*I(VDD)')
will give you total power dissipation supplied by VDD.
For unloaded CMOS digital circuit, the above two results may be very close because currents drawn from digital input signal sources are usually very low.
Reactions: allennlowaton
    allennlowaton
    V
site:edaboard.com hspice power measure
just use
.PRINT POWER
it will give you accurate power.
total power hspice code
.PRINT POWER
just calculate the total power
