Do you mean you want to specify some minimum field strength and use IE3D to predict how far a distance you can go with the minimum field strength? If yes, you can try to use the command Edit->Wave Propagation ... on PATTERNVIEW for it. It can predict the field strength if you provide a distance value.
thank u sir. i will check it tomorrow. if i give array pattern i can reduce my beamwidth? right?
sir, in ie3d 12. we need not to give the minimum three cells and rectanglization options to improve the accuracy. right? direct options are there in the window. am i right? it is really superb. it is enough to give only the AEC ratio.
1. Yes. You can reduce beamwidth if you use array.
2. I am not sure your question on minimum 3 cells. Rectanglization is to improve the efficiency not accuracy.
3. Before ie3d 11, we ask users to provide AEC size. Some people did not pay attention to it and they may use too large or too small AEC size for some problems. We decided to prive AEC RATIO. It is easier to control.
i want to measure the distance of coverage with minimum field strength = 5 v/m. but it is asking so many parameters in the wave propagation window. which value to be consider? it gives ex ey ez etc...
sir, i asked u some suggestions to reduce beamwidth.
The feature asks you for a range of x, y, z points and find the Ex, Ey, Ez or Etheta, Ephi for you. You can try to enter some x, y, z coordinates and chekc the values of Etheta and Ephi. You shouild be able to find the location with E-field about 5 v/m easily.
