powersys
Advanced Member level 1
How to measure the current flowing through the inductor (i.e. L1 in the figure below) in a buck converter?
The switching frequency of the LT1074 controller is 100kHz. Most of current sensors (isolation type, e.g. hall effect sensor) cannot measure up to 100kHz (bandwidth). Therefore, I plan to use current sense resistor. But where should I install the current sensing resistor, before L1 (near sw) or after L1 (near output)? Will the additional current sensing resistor alter the performance of the buck converter?
