how to measure line frequency in pic microcontrollers
raman00084
Full Member level 6
Full Member level 6
i want to monitor the line frequency of ac servo motor with 230v line
how can i measure the frequency in micro controller any ic available
kindly help
regards
kalyan
Too few details to suggest something...
Is it an AC line?
What resolution are you looking for?
What is the sampling speed?
Hello!
It's still unclear. Do you want to measure the frequency of the 230 V line? Just for your
info, it's a known value, and quite accurately.
Now if you're using a frequency variation for a synchrone motor, this is another story.
You can measure it with any micro controller. Even if your micro controller is a 1MHz device,
it will show 20 000 pulses for each period (at 50 Hz), and therefore its accuracy will be
around 1/20 000. More than enough.
Do this with a timer. Everytime you detect a rising 0 crossing of the sine wave, check your
timer, and you will get an exact value of the period.
Dora.
Choose a PIC with an internal 12 bit ADC.
Then you'll have to design an analog circuit that converts your target AC wave to a measurable DC signal.
You'll have to choose your measuring window.
for example: -250v on the AC side will be 0v on the DC side while +250V will be 3v on the DC side.
