How to measure CMRR for differential amplifier?
surianova
Advanced Member level 1
ASIA
h iall,
For differential amplifier, CMRR should be measure single ended or differentially?
(i shorted both input with ac=1). When i measure differetially, i get 300dB, when i measure single ended, get 90dB.
richloo
Full Member level 1
Isolated Island
what do you mean by cmrr of an amplifier?
CMRR=Adm/Acm
where:
Adm=differential mode gain
Acm=common mode gain
With both input shorted together, it means that u are measuring the Acm.
electronics_kumar
Advanced Member level 2
Tamilnadu
calculate cmrr
dear surianova can we conclude for mentioning ideal opamp we refering Acm
J
jiangwp
cmrr half circuit full circuit
With aspect to the definition of CMRR, the differentiall output has to be used, i think, when the differential input ports short together.
alok_ky
Full Member level 1
bangalore india
define cmrr in a differential amplifier
it is measures differentially,,,refer sedra/ smith for details.
nandu_r
Member level 1
cmrr of single ended output amplifier
the measurement depend opon how you tap the output
if your amplifier has single ended output, then you have to measure w.r.t single end output
surianova
ASIA
define cmrr in differential amplifier
ya, i mean Acm. All the value i get is in negative dB.
wanily1983
Member level 5
to calculate cmrr
in many classic referrence book, there are two definition of CMRR.
one is Adm/Acm, the other is Adm/Acm-dm.
i think we often care the later one. but i am not sure what the usage of the first one. hope for more.
the first definition is used in sigle-end output and the second difenition is used in fully differential opamp. in fact, they are the same just definiting the reject degree.
prabhu_psg
Junior Member level 1
hI WANILY
I feel the later definition hold only when u have a mismatch in the diffrential pair.I am very confused abt the first definition.How to calculate it using spice .
Humungus
Full Member level 6
ideal cmrr
It depends on which parameter are you interested. In a fully-diff amplifier there are several gains:
Ad_d : change in the differential output due to a change in the differential input
Ad_cm: change in the differential output due to a change in the common mode input
Acm_d: change in the common mode output dua to a change in the differential input
Acm_cm: change in the common mode output dua to a change in the common mode input.
gajen
cmrr=a/acm
You should measure output differentially. And measurement will be change in differential output to change in common mode input.
_AndrewS
Newbie level 1
cmrr differential output
By the way: do you have any idea how measure CMRR in Cadence Composer schematic? Which simulation I can use?
wanily1983
Member level 5
cmrr ideal opamp
hi,AndrewS
you can find what you want in chapter 6 of allen's book "cmos analog circuit design".
hope it helps u.
chu
Junior Member level 3
Re: CMRR
hi all , i'm new in analog design and i just read abt Acm in Gray/Meyer,
Acm=voc/vic and voc=(vo1+vo2)/2 ... so does it mean that we need to measure single-ended output on each side of outputs and calculate voc to obtain Acm ??
Please reply, thanks.
jinxingsun
Member level 5
CMRR
chaper 4 of Razavi's book discusses this point in detail
leonlin
Re: CMRR
beckchm
Banned
Re: CMRR
depend on your choosing configuration
huojinsi
Full Member level 5
Re: CMRR
I am confused by up posts.For differential amplifier, i think CMRR should be measured single ended. Because normally CMRR is defined at single-ended out mode.
alizadeh_m
Junior Member level 2
Re: CMRR
Hi, could someone explain generally when we use a half circuit.
