How to measure a fully differential OPAMP with SC_CMFB
skythunder
Junior Member level 3
vdb hspice differential fully acout=0
Hi, all,
I want to know how to measure the characteristics of a fully differential OPAMP with switched capacitor common mode feedback network. Obviously, we can't use continous time measurement methods(AC sweep) to find DC gain , Unity gain bandwidth, CMRR, PSRR,etc.
Are there any specifial methods to measure those parameters of an OPAMP, or just using transient simulation to approximate them ?
Hi, if you use Hspice, you can perform TRAN analysis, and save the operating points of the circuit to a file, and then you can load the file and perform the AC analysis. For example, you perform TRAN analysis:
.SAVE TYPE=IC FILE=RAIL2RAIL.IC LEVEL=ALL TIME=25U
.TRAN 0.1NS 30U START=0U
and then you can perform the AC analysis
.AC DEC 10 1 100MEG *SWEEP CC 0.5P 3P 0.1P
.LOAD RAIL2RAIL.IC0
you can get the help from the Hspice manul to understand the .save and .load!
regard!
.LOAD RAIL2RAIL.IC0
regard!
Thank you so much, wjxcom! I will try your method. And I want to know whether this way is useful for the simulation of other switched capacitor circuits, like SC filters, Since simulating the frequency response of SC circuits in Hspice within cadence is unavailable
Hi hr_rezaee: I think .op time can only print the operating points, for example, .op 25u can print the operating pointsat 25u. Do you have another way to simulate the fully differential OPAMP with SC_CMFB?
regards
regards
hi
.op time can print the operating points, but it can cause the .ac analysis in specific time.
try it.
regards
Hi hr_rezaee: I try to use your method, the netlist is:
.PROTECT
.OP 28u
.AC DEC 10 1 200MEG
.LIB 'D:\EXERCISE\DESIGNOPA\CSMC06\CSMC.LIB' TT
.END
but the result is not right!
.LOAD RAIL2RAIL.IC0
wjxcom said:
PROTECT
.OP 28u
.AC DEC 10 1 200MEG
.END
are these equal netlist?
I think no
Hi hr_rezaee: would you tell me how to use the .OP?
wjxcom, would you mind helping me analysis another SC circuit and giving me some advice ? the link is just another topic in this forum:
thanks
hi
could you test this two solutions on one netlist
and then report the results?
thanks
regards
Hi hr_rezaee: the circuit, the netlist of the circuit and the simulation result can be found at the attachment whose name is simulation.rar.
when I use the netlist as follows:
.NOISE V(OUTD) VID 10
.PRINT NOISE ONOISE INOISE DB(ONOISE) DB(INOISE)
.LOAD CASCODE.IC0
.SAVE TYPE=IC FILE=CASCODE.IC LEVEL=ALL TIME=25U
.PZ V(OUTD) VID
*.OPTIONS POST BRIEF NOMOD CAPTAB ACOUT=0 CSDF=2 PROBE
.PROTECT
.AC DEC 10 1 60MEG *SWEEP CC 1P 10P 1P
the .lis file is cascode_opa_ac1.lis, and the wave is Aim_ Printing1.pdf;
.PZ V(OUTD) VID
.PROTECT
.OP 25u
the .lis file is cascode_opa_ac2.lis, and the wave is Aim_ Printing2.pdf;
It is clearly that these two results is different!
Thanx you again to help me!
Hi
I tested it.
first try this netlist
.LOAD CASCODE.IC0
.PZ V(OUTD) VID
.PROTECT
then save the OUTD ac analysis.
then delete all fles except *.sp and model.
then try below netlist:
.PZ V(OUTD) VID
.PROTECT
.OP 25u
you can see that two plots are the same.
Don't use .op 25u and .load simultaneously.
regards
How about spectre? Can I do it in analog environment?
Hello, hr_rezaee
I did simulations with two files you provided but did not get same plot. The following two netlists are my control signals and analysis. Can you show me
how to fix the problem? Thanks
1.
.LOAD MYCASCODE.IC0
.SAVE TYPE=IC FILE=MYCASCODE.IC LEVEL=ALL TIME=25U
.PZ V(OUTD) VID
.PROTECT
.OP 25u
.LIB 'cmos35.txt' nominal
.AC DEC 10 1 60MEG
.print vdb(outd)
.END
2.
.PROTECT
.OP 25u
.ac dec 10 1 60meg
.print vdb(outd)
.PZ V(OUTD) VID
.END
.LOAD RAIL2RAIL.IC0
regard!
sc_cmfb is a dynamic common mode feedback, how to choose the dc operating points. if u choose operating points randomly, the results are wrong.
.LOAD RAIL2RAIL.IC0
regard!
hi mr,wjxcom
wouid you tell me why you select time=25u for this simulatin?
thanks
Hi sh.shadmand: I think you can use any time to simulation, but you must confirm that the output common voltage is stable!
.LOAD CASCODE.IC0
.PZ V(OUTD) VID
.PROTECT
.PZ V(OUTD) VID
.PROTECT
.OP 25u
hi dear wjxcom.would you explain me the structure of balun that you used in your netlist?
