Theres a simpler way. You need a very small resistor, eg a length of cable that can take the current, but has a high enough resistance to produce a voltage you wont have to amplify much to use a voltmeter with.
Depending on what you have you could also make a shunt for an existing current meter.
i wouldn't say that lem current sensors are cheap. in fact, hall effect are probably the most expensive. calibrated sense resistors are cheap and easy to use, but at 2000A... this might be too high for sense resistor practical? even 0.001 ohm resistor will require 2W dissipation. that kind of heat generated might influence the measurement reading.
what about those old current transformers you see on generator stations.
To measure 2000Amp current shunt is the best method if cost is the concern
you can use 4 500 amp current shunts in parallel. because 2 % accuracy is oK for you.
Use MANGANIN current shunts they have very low temperature Coefficient.
but you will have to break the connection if you use a shunt.
