scriptx007
Member level 1
how to match NC Drill File to Gerber File. i m having problem with NC drill file not matching with the gerber. is there any rule or standard to match the NC drill file to Gerber file .
All gerber Layers are pefectly matched , but when i import nc drill file to gerber file all drill holes gets scattered . what may be the prob? . i tried to set NC drill format as equal to Gerber Format . i.e. Integer & decimal (2.3 int/abs/leading/relative origin) . but still getting the same prob. The board is not designed by me. this is third party gerber. usually i set "2.3 int/abs/leading/relative origin" for both gerber & nc drill format when i desing the board . when i design the board & export the gerber with this format , it gets imported properly with all matched layers.
pls share ur thoughts.....
Rohan....
Rohan....
