Jan 30, 2007 #1 K kumi19 Junior Member level 1 Joined Jan 30, 2007 Messages 19 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,403 how to map virtual memory into physical memory using C
Jan 31, 2007 #2 O optor Member level 3 Joined Nov 25, 2003 Messages 62 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 350 Re: mapping of memory That's a work of OS or computer architecture?
Feb 1, 2007 #3 K kumi19 Junior Member level 1 Joined Jan 30, 2007 Messages 19 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,403 mapping of memory no it should be explictly done during coding and has used in the same way....
Feb 1, 2007 #4 Y youngfly Newbie level 2 Joined Jan 30, 2007 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,287 mapping of memory Using C needn't consider the hardware.
Mar 5, 2007 #5 K kbrahma Newbie level 4 Joined Aug 14, 2006 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,324 Re: mapping of memory It will be done in the OS startup code in a stand alone system. Just check with the OS manuals and your hardware specs.
Mar 7, 2007 #6 ivar4ever Full Member level 3 Joined Jun 12, 2006 Messages 189 Helped 25 Reputation 52 Reaction score 5 Trophy points 1,298 Location India Activity points 2,437 Re: mapping of memory no need to do that using C, it is taken care by the OS, and the compiler.
Mar 8, 2007 #7 dharmeshpitroda Member level 2 Joined Mar 5, 2007 Messages 46 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,288 Activity points 1,565 mapping of memory I think we can also do it by using pointer.... i dont know exactly but far and huge pointer funda help us....
Mar 10, 2007 #8 E ebook123456789 Member level 2 Joined Mar 8, 2007 Messages 47 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,461 mapping of memory sure you can do it by writing your own mem management code if you want
Mar 13, 2007 #9 M microtronics Newbie level 3 Joined Mar 13, 2007 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,295 Re: mapping of memory no need to do that using C, it is taken care by the OS, and the compiler. Added after 41 seconds: no need to do that using C, it is taken care by the OS, and the compiler.
