how to manage a IC design project
AndyJing
Junior Member level 3
thanks,
can give some book about it ?
wadaye
Full Member level 4
Re: how manage a IC design project
Hi AndyJing:
I think first of first the Project Manager should know the IC design flow
well, otherwise the management will be a big problem.
cnspy
Full Member level 3
You can enter a Project Management training
AndyJing
who can give some classical books about IC project management
cnspy
Full Member level 3
Project management does not depend on it context. It is method only.
wufengbo
I think you are right.
IC design project is generally like software project. Of course, there are some difference between them. But, for a project perspective, they are the same, I think.
reza56
Junior Member level 1
I think managment is really a kind of art and you can get this skill by training.But you first must start from knowing the main steps in the IC design .
I think that this book can help you(but if you are intersted in digital design)
digital CMOS gdesign author:Yusuf Leblebici,and another one that I don't know him.
AndyJing
asic handbook is good book,it make some suggestions about asic project management.
i need more detail book
jimjim2k
Advanced Member level 3
Hi
Is there anything like CVS (concurrent version control) for IC design?
I think if it will be then it will be fantastic and WOW!!
tnx
troops
Member level 3
u can join some team ...
and cowork with a project ...
u will leran at all efficienctly..
ic_design
First you must know :
(1) Design Flow
(2) IC Design Knowledge: can find solution to any question in project
(3) System Spec.
And then, you must have a schedule, and must do the best you could finish it on schedule.
minaflying
Junior Member level 2
to be a project manager is a had thing,we will try our best to do it.
krishna31
You should know the over all knowledge of the ASIC flow.
Plus u should know, how to manage the people and track the action items. Expereience is the good teacher.
Regards,
krishna
rx300
Member level 3
jimjim2k said:
Hi
tnx
We used CVS for IC design before, i.e., rtl, verification environment, test cases etc.. We switched to S/y/n/c/h/r/o/n/i/c/i/t/y 2 years ago. The P/r/o/j/e/c/t Sync and D/e/s/i/g/n Sync products proved to be useful for teams all around the globe.
ASIC project management usually requires good understanding of the flow, from front-end to backend, and from tape out to ATE to lab validation. It's not easy. Books are usually written by professors who don't have know much about industry practice. There is something that can only be learned by doing it, not reading from books.
Just my 2 cents.
