The YOST standard is for connecting one serial port to another using RJ45 connectors and CAT5 cable. It still needs a comms port at both end, it doesn't convert Ethernet to serial at all, it's just an alternative way of wiring what is normally done with 9 or 25-pin 'D' connectors.
Brian.
Pashok84, have you changed your mind, or are you just confused about the capabilities of your notebook's RJ45 connector? It surely does not provide RS232 connectivity. Review the handbook in case of doubt, and please correct me if I'm wrong.I want to connect my microcontroller board serial port with my laptop ethernet connector, as i don't have serial port in laptop.
The popular RS232 over "RJ45" assignments are using RS232 level.use serial line in TTL level in RJ45
Several interconnect standards are partly using P8C8 modular connectors and Ethernet cables, e.g. CAN Bus. Besides the ability of using standard connectors and cables, you can also share the infrastructure cabling in office buildings.I am just wondering what will be the advantage of using RJ45 cable insteaded of RS232 cable.
