How to make pins outside the cell in Virtuoso Layout Editor?
Ahmed Atiya
Egypt
Hi all,
In virtuoso layout editor, I want to make a cell from my layout and connect it to another cell. The problem is that after making a cell by selecting the layout and executing make cell, the pins are inside the cell and cannot be connected so I want to know how to make the pins outside the cell.
thanks,
Re: Layout question
You can just connect by connecting the pins with the same metal layer. Virtuoso will understand this. There is no need to make the pins outside.
Layout question
When you make a cell . the connective of layoutxl is miss . you should create pin in the make cell .
Layout question
Create new pins in the cell which is made
Layout question
if you don't want to creat to new pins, you can connect then with the same layer.
