can i get a example PIc programming to interface with bluetooth. what coding i want to put to make my pic16f877 connect with bluetooth. i just want to make the PIC programming 'ON' and 'OFF' when it get the ascii code from bluetooth.
Usually, the Bluetooth modules are interfaced to the microcontrollers via serial port. As a result, the code for Bluetooth is the same as the code for the serial port.
if u dont mind can u give some programming how to start to program the serial port for PIC16f877....i want to detect the ascii code which send by bluetooth..
Go to google and search for "PIC16f877 [your compiler] serial receive". I'd be happy to do this search for you, but I don't know which compiler you are using.
