How to make numlock on at startup?
elecomm
Junior Member level 3
I need to have numlock on by default on startup ...I am using FC3..I found this command on fedora.org
yum install numlockx
they say I need to be root and online..but when i write this command it doesnt change and I receive the following lines...
[root@shaban ~]$ yum install numlockx
Setting up Install Process
Setting up Repo: base
repomd.xml 100% |=========================| 1.1 kB 00:00
Setting up Repo: updates-released
**broken link removed** [Errno 4] IOError: HTTP Error 404: Not Found
Trying other mirror.
repomd.xml 100% |=========================| 951 B 00:00
Reading repository metadata in from local files
base : ################################################## 2622/2622
updates-re: ################################################## 910/910
No Match for argument numlockx
Nothing to do
please anyone help me with that...
Quck search on google: **broken link removed**
But simpler, check your BIOS and see if you can turn NUMLOCK on there. ost modern BIOS allow this.
    elecomm
There is option to keep the numlock on or off in BIOS.
It looks like the numlockx package was not found by the installation utility in any of the package servers.
you can add following lines to /etc/rc.d/rc.sysinit
for tty in /dev/tty[1−9]*; do
setleds −D +num < $tty
done
reference at Configureation HOWTO
