How to make modelsim to take the ini file located in work directory
kalyansrinivas
How to make modelsim to take the ini file located in project directory
Hi
Modelsim takes the default ini file
In my case the default ini file is write protected and i am unable to update with new libraries compiled
I have a ini file with newly compiled libraries in my project directory
but how to make the modelsim select the new updated ini file in my project directory instead of the default one
Regards
M Kalyansrinivas
shanmugaveld
Bangalore
if you are creating the default library(work) through command prompt. Usually it will create the local ini file in the working directory, automatically.
Try below commands to create the work library.
vdel -all /// delete all the library
vlib work /// create work library
vmap work work /// mnap it to the work lib
