How to make a zero crossing detector of constant amplitude ?
extradeath
Member level 2
Alexandria, Egypt, Egypt
zero crossing detector optocoupler scheme
Hi friends
Do anyone know how to make a zero crossing detector of constant amplitude that doesn't depend on the source.
to be used as an input to a Pic interuppt to start a certain event
Please Help if you can
Re: Zero Crossing Detector
hope this helps in a way...
This design is very cool,
yeah, nice ideea,
//a
PS another solution is to use a simple optocoupler for 0 crossing detector. At the input stage you need an resistor and a dioda, and at the output only a resistor. This method is not acurate like traxonja presented above.
The most basic design scheme is to use a fast comprator like LM311 with dual supplies (+ve and -ve), then set the comparator +ve I/P to a two similar ersistors (10kΩ say) to compare the signal voltage with a true 0 volt. I prefer that u set one of the two resistors as a potentiometer to acheive a true 0V.
Hopt this helps.
