how to make a seven segment based count down timer for traffic signal using atmega 16
prashanttyagi85
india
dear all
i am working on traffic signal's countdown timer.
as everyone know that timer shows the remaining stop time for that road.
it starts from final value & reduce upto 0 till the signal is changed.
i have to read the red signal first of all then calculate the time then convert it into seconds then send it to 7 segments then reduce it by 1 second & change it on 7 segment.
am i write?
if yes then how to convert time into second & send it to 7 segment?
is nobody interested to tell me about it?
You need to load the timer register first with the HEX value of your time count.
Timer Count=1/((1/12)*Crystal Frequency)
This is a system consisting of several circuits. It is hard to visualize the entire layout from your verbal description.
The method I'm used to seeing, is to load a desired value into the seconds timer, then start it counting down.
actually we are not having any desired value here.
we have to detect the red signal then read it in first cycle
after that wait for next cycle
in next next cycle again read the red signal
then compare the first red signals time with second one
if both time are same then display it on 7 segment in next cycle with count down
now we have to read it in each cycle that the red value is same or not
It as a clever approach for automatic time lapse calculation. You dont have to feed any value for time but by calculating time taken for red signal, seconds count value is updated accordingly making setup real easy.
dear all after a long time i worked on this count down timer.
i am posting the code here please help me in this code as i want to use here timer interrupt.
#include<avr/io.h>
#include<util/delay.h>
#include<avr/interrupt.h>
#define F_CPU 16000000UL
char digit[] = {0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6};
char count=0,sec=0,tensec=0, halfsec=0;
char i=0,j=0,one=0,ten1=0,one1=0,ten=0,hun=0,sec1=0,k=0,track=0;
//char greencount=0,greensec1=0,greentensec=0, greenhalfsec=0;
void main()
	DDRD=0xFF;
	DDRB=0x00;
	DDRA=0xFF;
//	sei();	// set intrupt enable
	while(1)
	//	PORTA=0xff;
	//	PORTD=0xff;
		if(PINB & 0b00010000)
			_delay_ms(5);
			read();			//function to read the i/p.
		sec=sec1;
		breake(sec);		//function to break sec into ones, tens
		display(one, ten);	// to display on 7 segment
read()
	_delay_ms(20);
	while(PINB & 0b00010000)
		count++;
		_delay_ms(5);
		if(count==20)
			tensec++;
			count=0;
			if(!(PINB & 0b00010000))
				break;
		if(tensec==5)
			halfsec++;
			tensec=0;
				break;
		if(halfsec==2)
			sec1++;
			halfsec=0;
				break;
breake(sec)
	if(sec<=99)
		hun=0;
		one=sec%10;
		one1=one;
		ten=sec/10;
		ten1=ten;
	else
		hun=1;
		one=sec%100;
		sec=sec/10;
		ten=sec%10;
display(one, ten)
	for(i=ten;i>0;i--)
		PORTD=~digit[i];
		for(j=one;j>0;j--)
			PORTA=~digit[j];
			_delay_ms(1000);
		if(j==0)
			PORTA=~digit[j];
			_delay_ms(1000);
			one=9;
	if(i==0)
		PORTD=~digit[i];
		for(j=one;j>0;j--)
			PORTA=~digit[j];
			_delay_ms(1000);
	if(i==0&j==0)
		PORTD=~digit[i];
		PORTA=~digit[j];
		_delay_ms(1000);
		one=one1;
		ten=ten1;
the basic funda behind my project is
i have to read a +ve signal which i am reading using PB4 pin of atmega16.
when signal on, i have to detect it, count the time upto which it remains on, & display it on 7 segment.
so i used here function read() to read it
function breake() to convert it for display
Function display() for display it
i am doing here polling
but it is not an efficient method so please any body arrange my code with the help of timer interrupt.
thanks
dear all
please send any suggestion or correction in my code for removal of my problem
thanks to all for reply
When PB4 becomes high, start the timer and when PB4 becomes low then stop the timer. In the timer interrupt routine increment ms, sec, hour counters. The values of ms, sec, hour counters will give you the time for which PB4 was on. If you want more precision then incluse a timer interrupt for one us. Then increment the ms, sec, and hour counters depending upon the value of counter used for us.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
//Timer0 Prescaler = 0; Preload = 16; Actual Interrupt Time = 1 us
//Place/Copy this part in declaration section
void InitTimer0(){
  SREG_I_bit = 1;
  OCR0 = 16;
  TCCR0 = 0x28;
  TCCR0 |= 0x01;
  OCIE0_bit = 1;
void Timer0Overflow_ISR() org IVT_ADDR_TIMER0_COMP {
  //Enter your code here
  OCR0 = 16;
  us++
  if(us == 1000){ms++; us = 0;}
  if(ms == 1000){sec++; ms = 0;}
  if(sec == 60){min++; sec = 0;}
  if(min == 60){hour++; min = 0;}
  if(hour == 24){day++; hour = 0;}
//Display day:hour:min:sec:ms:us
thanks for reply & sorry for responding so much late.
please also tell that in your code line no. 13 said that "enter your code here" it means that should i write the code for displaying the data at 7 segment? or else.
