How to make a gaussian channel in Matlab?
bee
Full Member level 2
Full Member level 2
can any one plz tell me how to make a gussian channel in matlab....i dont want to use the build in function awgn.
Waiting....
AWGN ???
hi
since AWGN contains all frequencies in the signal bandwith , and its PSD is constant and equal in all frequencies , i.e PSD(f)=N0 . you only need to create the samples of gaussian random variable in your signal BW. In other words ,if B is the sinal bandwidth , define n=sigma*randn(B,1); and add it to the signal s :
r=s+n
the awgn function in Matlab simply does the same as above.
regards
    bee
Re: AWGN ???
tx allot for ur help.
can u tell me what is sigma and why u have used it?
Waiting....
Re: AWGN ???
hi
sigma is the standard deviation of the gaussian noise which is equal to the square root of the noise power :
to get a better view , let Eb be the energy of the transmitted signal bits, and signal to noise power ratio be SNR, then for a baseband system:
SNR=signal power/noise power= S/N=(Eb×Rb)/(N0/2 × Rb)=2×Eb/N0
where N0 is the power spectral density of the bandpass noise and Rb is the signal bit rate (≈signal bandwidth). hence ,
sigma= √N=sqrt(Rb×N0/2)
it's that simple
:D:D:D
regards
