Inkwaterman
Member level 1
Static rele
Hi !
I have the following problem:
I have an IC ( AD420 ) with 2 different exit , a current exit , usually 4-20 mA and a voltage exit, usually 0-5 V .
I want to do a circuit with only one exit , where I can select the exit type via software, but for do this I must connect the current and voltage exit to the same circuit exit. Is correct use a rele for connect the 2 IC exit to the circuit exit ?
If my solution is no good, could you suggest me another one?
Thanx.
Hi !
Thanx.
