How to make a 1 Hz clock circuit?
gie_b_hsb
Junior Member level 2
Please everybody, how to find or made clock circuit with 1 Hz frequency, please help me ....?:cry:
budhy
Advanced Member level 3
Indonesia
Re: Clock circuit
Please take a look at this circuit:
IanP
Advanced Member level 7
West Coast
Re: Clock circuit
One option to generate 1Hz, or 1s clock, is to use 555 timer ..
If C=10µF and RA=RB=R here is the formula to calculate R:
T=0.693(RA+2RB)*C=2.079*R*C
R≈48.1kΩ, so use RA=RB=47kΩ and add 2-5kΩ trimmer to RA or RB to set 1s ..
Regards,
IanP
gie_b_hsb
Re: Clock circuit
thank's for all, as soon as i try this schematic....?
sorry.... any have voltage regulator with CT transformer circuit......?i say again many thank's for your help.....?
Gie
hazemafify
Full Member level 1
Re: Clock circuit
oh! it's easy circuit you can search in google by keyword "ic 555" you will get the schematic of the 555 timer and the equation that you can get the values of resistors and capacitors or you can search about the toturial and simple program that calculate the valuse of R's and C's .
and another way but it's not efficient that buy crystal
manish12
Re: Clock circuit
you can use blink led also.
you can also use the supply freq for ref. with counter.
atferrari
Full Member level 4
Full Member level 4
Buenos Aires - Argentina
Clock circuit
Look for a discarded quarts clock. Most of the times their oscillator circuits are intact.
With a scope, even a with a multimeter, you could identify the point where there is a 1 Hz pulse.
gie_b_hsb
Re: Clock circuit
thank's for all.
i think, i need any clock generator for my counter circuit which the IC i used are 6 HCC40110B from ST electronic with six 7 segment, so that the result are x.xx.xxx,the last three digits equal 1/1000 second. how to find clock generator for this circuit.....?
once again i said thank's a lot for you any kind......
rgds,
gie
echo47
Advanced Member level 6
USA
Clock circuit
Does x.xx.xxx mean 9 minutes 59 seconds 999 milliseconds? If that's true, then you probably need a 1 kHz clock, and you probably want it to be more accurate and stable than a 555 circuit.
You could buy a crystal oscillator that is a convenient multiple of 1 kHz, and then divide it down to 1 kHz. For example, buy a 2.048 MHz oscillator and an 11-bit binary divider. Or maybe a 1.000 MHz oscillator and a three-stage decade divider.
gie_b_hsb
Re: Clock circuit
it's true 9.59.999, do you mind to give pulse generator circuit, i tried a simple 555 circuit but this circuit not running well. in this topic have circuit using 4060 & 4017, is it match with my circuit..?
rgds,
gie
budhy
Indonesia
Re: Clock circuit
CRYSTAL-CONTROLLEDTIME-BASE GENERATOR with 4060 & 4017 (27654.pdf) generate 1 Khz clock, it is exacly what you need.
gie_b_hsb
Re: Clock circuit
dear budhy and everybody to help me...
oke, i trying this circuit....
sorry budhy do you have personal email....?
thk's for all
rgds,
gie
gie_b_hsb
Re: Clock circuit
Dear all,
How to change digits number 9.99.999 to 9.59.999....
Thks
rgds,
gie
bigaussie
Member level 2
Member level 2
Re: Clock circuit
buddy 555 is the best option available
daviddlc
Full Member level 5
Full Member level 5
USA
Re: Clock circuit
I don't think the 555 is the best option for a clock, you need something more stable.
bharitta
Re: Clock circuit_2
please everybody help me, i had build counter up/down using IC HCC40110B, and the circuit is running well, but if i push the stop button, the counter digit on 7-segment not stop fully, so that please help me to find this problem....
thanks...
regards,
Gie
randell_xtian
Full Member level 4
Full Member level 4
Philippines
Re: Clock circuit
try the post circuit diagram by IanP it will work. you can used the principle behind the 555 monostable timer.
regards to your project!^^
randell_xtian:D:D:D
