gunnerunbeaten
Member level 2
when i write code below :
after synthesis , there is error : " Target slice is 5 elements ; value is 4 elements ". Then i change inputs to 5 elements, but the timing is increase.
in verilog 4 bits + 4 bits => 5 bits is OK, how to do that in VHDL?
library IEEE;
use IEEE.std_logic_textio.all;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
signal stage1 : unsigned (63 downto 0);
signal stage2 : unsigned (39 downto 0);
[COLOR="#FF0000"]stage2(4 downto 0) <= stage1(7 downto 4) + stage1(3 downto 0) ;[/COLOR]
