how to load bootloader to at91sam9260?
impet14
Junior Member level 3
Thailand
I've had Olimex board.and I need to know how to load bootloader by sam-ba program from atmel web.
thanks in advance.
Hi
You need to compile the bootloader code and produce a HEX or BIN programming file
And program the file using an external programmer or a JTAG programmer or directly from your compiler debugger (depend of type used)
All the best
Bobi
The microcontroller specialist
plug a usb cable to Olimex board,
pu will detecting your board, (installed driver)
run samba
load bin file to you board
