How to load an image from a fingerprint scanner in Matlab?
fatimajoy
Junior Member level 3
hi! how can I load an image from a fingerprint scanner into matlab? thanks!
load image in matlab
hi
It's very simple .
if u refer to toolbox help (Image processinh) u can find your answer
how to read image in matlab
I guess, its not that simple. If you have to read from the scanner, then I am afraid you have to interface with the device?? I personally have not done any in Matlab. But i think there is no alternative.
regards,
cedance.
load image matlab
heloo
how to interface with matlab plz help me
reply soon
Added after 1 minutes:
what command will be used in matlab to interface with hardware
matlab image load
If you are doing post processing use:
READBMP Read image data from a BMP file.
READGIF Read an image from a GIF file.
READHDF Read an image from an HDF file.
READJPG Read image data from a JPEG file.
READPCX Read image data from a PCX file.
READPNG Read an image from a PNG file.
READTIF Read an image from a TIFF file.
READXWD Read image data from an XWD file.
RJPGC Read a JPEG image.
RTIFC Read a TIFF image.
To do real time acquisition from your Scanner you will have to get the programing
info from the scanner and figure it out yourself. You might be able to use
a MEX file or Active X in Matlab.
Good luck
how to read a image in matlab
I found the mex file for the scanner but how can i open the file in matlab? is there a command for this? thanks!
    V
Re: how to read a image in matlab
what is mex file and where you found plz help
