How to link Dx designer with pads layout
Monolisa5791
Member level 3
Hi all,
While cross proping the DX designer schematic with pads layout i can't able to compare design , either forward annotate or backward annotate....i am only getting the message
" xxx.proj is not in the Dx designer path,pls change the project path or enter a schematic name that is in the current path"
Can anyone give the detail procedure to send the nelist from Dx designer to pads layout by back annotate method.
senilicus
Full Member level 5
Amsterdam / The Netherlands
1) Open the schematic with DX-designer
2) View -> Other Windows -> Attributes
3) Select the PCB tab on the attributes window
4) Click on the traces symbol, (Create refdes), a popup will open
5) On the popup window, at the "format information" part, you can select the desired netlist format.
6) Click the "run" button"
Have fun
suhas kulkarni
Newbie level 3
I am using Expedition
I want Expedition Full flow
Added after 2 minutes:
hello I am new user for Expedition I want the full flow.Also I want to know how to set the constainents in Expedition.
Thanks,
Suhas
