how to know whether microcontroller is working
siva_2smart
Newbie level 6
working of microcontroller
hi,
I am using a development board in which when i am dumping some small programs like glowing an led also it is not working ... I think the microcontroller is not working.
So can anyone please tell me how can i identify the problem. Especially how can i know if microcontroller is working or not.
how to know microcontroller
replace the same code with a new chip, or assumed-to-be working chip or a chip which you see working with someone..
then you will know..
microcontroller working
siva_2smart said:
hi,
Usa a simple program that i.e sets pin0 and pin5 and resets other pins.
Use a metrix or a led to check if the µC works well or not.
how to check microcontroller is working
what if the configuration bits are not set right while programming,,,??
what to know about microcontrollers
I had already tried working with some small programs like glowing leds but its not working
Does giving 12v at any pin of microcontroller burns it.
Be carefull man !
PICs require power supply between 3.7V an 5 V.
how to know if microcontroller connected
Applying 12 Volts can damage the complete IC or sometimes the specific pin.
how to check microcontroller is working or not
havent you read my post above..
fry pin on microcontroller
Have you checked your crystal?
Have you tried all the ports?
The tolerance of most of microcontrollers in input mode is +5v(max)
So, your +12V might have damaged that pin.
If your controller pins are configured in push pull mode try to measure the voltage on them after configuration before running the code.
how to check whether microcontroller is working
If you using high frequency osc then you need at least 5V power supply. Also need to turn off watch dog timer WDT. Also check reset pin mc**
And build a simple program to blink or just light leds on and off. Also you for sure need to include right header file. For example pic16F887.h This file uses c code to send right c code instruction to right places in MCU.
Try to find .hex files on internet. it worked for me.
there is a possibility that your programmer do not work due low voltages from your PC. solution should be another desktop PC.
how to know if microcontroler is working
check osc_out pin...it should give a clock of freq some mutiple of crystal u use
microcontroller not working at all
12 volts? it doesn't take much over 6 volts to fry a pic. Read the data sheet.
When you try another pic use a volt meter to test you input and output to see if its working.
gogo
when ever i try to load hex file to 89s52 by asim khan,s software it shows " no response from mc" wat may be the problem?? i have build the ckt correctly... how can check my mc working or not??
Hey check your all configuration bit of microcontroller.
WDT should be disable
What clk are you using ?
Internal /External , without this microcontroller can't work.
Just check this basics things
Regards
Chanchal
to siva_2smart:
hi i had uploaded the circuit diagram, code for led blinking. you can check that here
http://www.free8051projects.blogspot.com/
to niekiran:
use asimkhan software version isp v3.0. you can download it from the above site.
i also faced similar problems with higher isp version.
the programmer cable is simple and easy to design
Re: working of microcontroller
siva_2smart said:
hi,
which controller u r using?
if you have CRO then check ALE signal of the controller it wil give pulses, then it is working.
