Hi
I am very confused with antenna design because Im not 100 percent sure about the wavelength and how to design the antenna properly.
Let say, I am interested to build an antenna using a can. I have to drill a hole with a precision measurement from the bottom of the can to somewhere up to 20mm then insert the wire using the N-connector throught the hole and I have to make sure that the length of wire must be accurate otherwise.....
How i know the length of antenna, let say, omnidirectional antenna is the correct.
I don't really understand these stuff. So can anyone help me?
Maverickmax
