[PIC] How to know the percentage of memory used
MUKESH.K.S
Full Member level 1
Full Member level 1
KERALA
When we program the 16f series PIC uC using the HITEC-c compiler ,it will show the percentage of memory used in the output window while building the program.
Is there is any method to view the percentage of memory used in the C18 compiler ?
Thanks for the reply.........
actually i want to view an output window like in HITEC -c compiler , below i am copying the display of HITEC -C
Memory Summary:
Program space used 64Bh ( 1611) of 2000h words ( 19.7%)
Data space used 3Ah ( 58) of 170h bytes ( 15.8%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Configuration bits used 1h ( 1) of 1h word (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Loaded D:\works\WORKS\PROJECTS\LED Display\leddisplay.cof.
********** Build successful! **********
Is this a change request addressed to the compiler manufacturer? C18 is however legacy software, no more actively supported. You would ask for XC8 features. But XC8 is Hitech-C, it probably has the intended function.
