how to IP block that no one can modify/see its contents???
khaila
Full Member level 2
Full Member level 2
ncprotect
I have several HW implementaion blocks that I develop.
I want to share them but I don't want the other ppl to see its content.
Just to use it as black box.
something like EDIF files.
how I can generate like this desire???
modify its contents
I think you should read "reuse methodology manual". It'll answer all ur questions. its available in the forum
Added after 3 minutes:
top ip blocker
u can convert to blackbox by adding
`protect at the beginig and `endprotect at the end to ur source code.then compile in verilogXL with
verilog filename.v +protect.then it wl generate encrypted file with .vp extension
ex:
`protect
module xyz();
endmodule
`endprotect
Added after 43 seconds:
NCprotect option is directly available in nclaunch by rightclicking on file
ncprotect options
ex:
`protect
module xyz();
endmodule
`endprotect
What if I am using VHDL???
LaTeX Commands Quick-Menu:
