How to interpret a TTL signal with 16F887?
calamaro
Newbie level 3
Hi to all, I have a 16F887 pic and I have connected at pin RA4 a TTL signal like in attached picture. How can I write a function that recognise the time of a low or high signal transmitted? If the signal is (low or high) for 256µs I have to put into an array 0 otherwise if the signal is 512µs I have to put into an array 1. Like in the picture the time measure of signal must be from low to high of the square wave.
Thanks to all for your help
hameeds01 said:
u can use Capture Pulse Width from CCP Register
I've never used CCP Module, could you post an example please?
