How to interface TLC 0831 with 8051 in Assembly?
garg29
Advanced Member level 1
tlc0831 with 8051
dear friends
can anybody guide me on how to interface TLC 0831 serail adc with microcontroller 8051 in assembly language.
where can i find this topic or link to this topic
waiting for reply
with best regards
amit
tlc0831 with 8051
The best way is to read the datasheet of the ADC0831, if you will be using assembly, you can bit bang SPI communication.
Re: tlc0831 with 8051
AD_CS BIT P1.0             ;CS, CK and DO fitted to port 1
AD_CK BIT P1.1
AD_DO BIT P1.2
AD_RESULT equ 030h;        ;This variable holds result from A/D conversion.
    		MOV P1, 0FFh
    		CLR AD_CK
    		CLR AD_CS      ;Select chip (initiate conversion)
    		MOV R1, #02h
PREPARE:    SETB AD_CK     ;MUX settling time
    		ACALL delay_us
    		CLR AD_CK
    		ACALL delay_us
    		DJNZ R1, PREPARE
    		MOV R2,AD_RESULT
    		MOV R1, #08h    ;Read in value from A/D convertor, 8 BITS
CONVERSION: SETB AD_CK
        	ACALL delay_us
        	MOV C, AD_DO
        	MOV A, R2
        	RLC A           ;Left because MSB comes in first
        	MOV R2, A
        	CLR AD_CK
        	ACALL delay_us
    		DJNZ R1, CONVERSION
    		MOV AD_RESULT, R2
    		SETB AD_CK       ;cycle clock once.
    		ACALL delay_us;
    		CLR AD_CK
    		ACALL delay_us;
    		SETB AD_CS       ;Deselect chip.
delay_us:                    ;FOR STANDARD 12 CYCLE and 11.0592 MHz
			MOV R3, #05h      ;10 uS
			DJNZ R3, $
			RET
