How to interface speaker and mic?
skakz
Newbie level 6
speaker and mic
can anyone tell me how to interface a speaker and a mic with a microcontroller
thx
speaker and mic
I think if you tell the application and the purpose then it would be easy for us to tell you how to do that.
Re: speaker and mic
it's for a mobile based on a microntroller (vowifi)
speaker and mic
At minimum you need a preamp and an ADC for the microphone and a DAC and an audio amp for the loudspeaker output.
There are microcontrollers which have built in ADC's and PWM outputs. Voice processing will require a significant amount of processing power and buffer memory, you will need a high end microcontroller for this, paticularly if you are going to use a speech codec or do echo cancelation.
You might find that some analog processing before the ADC such as some filtering and AGC will make the device perform better.
Re: speaker and mic
my microcontroller contains DAC and ADC I am asking about the exam circuit
thx
