Re: Interface with RCA cable
Thanks IanP, for your quick response.
The RCA cable only consists of 2 wires; 1 for ground and another one for receiving the signal, am i right?
The transducer i used is from Navman company. It is a single frequency transom mount depth transducer.
So, i just need to connect a resistor in between RCA output and its ground then supply it with voltage.
Do i need to construct any transceiver or echo sounder to this device?
Thanks a lot.
Its specification only indicate that Max. power consumption: 60mA
and Current Drain: 150mA
Its supply voltage is 9.5V to 16.5V
