How to interface Garmin GPS 12 XL to PC?
alzomor
Advanced Member level 2
Cairo
Garmin GPS 12 XL
Hi
I have a Garmin GPS 12 XL.
but it's LCD is broken.
How to interface it to the PC?
Salam
Hossam Alzomor
www.i-g.org
zahidkhan
Member level 2
Re: Garmin GPS 12 XL
It should have a usb or serial port interface.just connect it to the respective port of the PC with cable and use the software provided with GPS.U can use any other third part software like VisualGPS or just see the raw output (NMEA form )by using the terminal program.
regard...
alzomor
Cairo
Hi
Thanks for your reply
My question is
At which buad rate dose it work?
Dose it initially work at NMEA of it may start with another formate.?
What is the pin connection of the serial port?
Salam
Hossam Alzomor
www.i-g.org
zahidkhan
Member level 2
Usually it works with the baud rate of 4800 and starndard serial cable. U better see the manual of 12 XL.
