How to Interface FPGA with DSP(TEXAS)
jonatan
Member level 1
dsp texas 28xx
I am new on this area.
Anyone know if it is easy interface a FPGA (XILINX or Altera)
with any of the available DSPS (Texas TMS320) or Analog Devices
(ADSP21161).
vonzhaoqun
Junior Member level 2
china
dsp interfacing with sram
hi,
it is very easy,i am making a interface betwen tms320vc5416 and xilinix fpga(spartanii),do you get any question?
tlp71@hotmail.com
Full Member level 4
dsp connect fpga
what do you would interface?
Serial port?
Address-space?
i-o ports?
HPI?
is very simple to interface
bunalmis
Full Member level 5
Ireland
If you can use standart TTL family in your DSP project.
You can use easly FPGA.
What is the problem ?
Gunship
Member level 2
Anyone know if it is easy interface a FPGA (XILINX or @ltera)
(ADSP21161).
Depending on what you want to do. I usually program the FPGA as a memory device and connect it directly to the main DSP bus. As a result, the FPGA will look like anyother memory / devices that connect to the DSP.
I will not recommend using the HPI in this case. Most of the time HPI is used to interface to a micro-controller. It is not necessary to use it for FPGA. (Of course, you can if you want to.)
If you don't know how to connect the FPGA, look up how to connect an SRAM for your DSP and examine the interface timing. Then design your FPGA to look just like the SRAM. I am sure you can find App notes on how to connect an SRAM to your DSP.
Good luck
Gunship
Gunship
Member level 2
BTW, make sure your interface voltage standard is compatible. e.g. 3.3V bus connect to 3.3V bus, etc.
Gunship
nattawoot_s
Newbie level 5
I think that same as interfacing with microcontroller.
spit
Member level 2
DSP to FPGA
with regard to the Analog device you mentioned, check out the section in the Sharc user manual relating to host interface, all the details are clearly shown and it can be achieved with a FPGA.
Spit
paviljonac
Junior Member level 1
using TMS320C5510 and virtex2. you can interface thru EMIF of dsp, where FPGA is configured to be seen as static memory space, or thru McBSP serially if suitable.
