How to Instantiate a VHDL entity in verilog module ?
blooz
Advanced Member level 2
India
How can we instantiate a VHDL entity inside a verilog module .I am using Active HDL..
Alexium
Full Member level 2
Ukraine
You just have to instanciate module header that would be semantically the same as VHDL entity. When the VHDL module is added to project and you want to use it inside Verilog module, you simply imagine that VHDL component is written in Verilog and use it as if it actually is.
FboDigit
Member level 1
Canada
And pray that there is no array in your VHDL code because verilog don't yet support array on inputs and outputs.
syedshan
Advanced Member level 1
Jeonju, South Korea
Yes Alexium is right, just treat your VHDL enitity declaration as if it is a verilog module declaration. and do the same instantiation as in for verilog modules.
eng.amr2009
Junior Member level 3
Egypt
High there
If the VHDL component has generics, Does the generic mapping work inside a verilog module
simply MyFile.vhd is a generic VHDL entity instantiated inside MyTop.v ... Does the generic mapping of MyFile.vhd inside MyTop.v work ?
thanks in advance
ads_ee
Full Member level 6
San Diego
yes it works. I'm using this in a current project.
Just assign the generics as if they were parameters in a Verilog module.
FvM
Super Moderator
Staff member
Bochum, Germany
Some tools, e.g. ModelSim are restricted to old #( ) parameter style instead of newer defparam syntax.
ads_ee
Full Member level 6
San Diego
You have that backwards....
defparam was defined in Verilog-95 they added #( ) syntax in Verilog-2001. You can still use or abuse defparam in Verilog-2001.
I started using #( ) syntax when the Xilinx tools started supporting it (after lots of complaining by me an a lot of other engineers)
-alan
Reactions: FvM
    FvM
FvM
Super Moderator
Staff member
Bochum, Germany
You see that I'm not primarly using Verilog, I suppose you are right, thanks for clarifying things.
I wonder however, why ModelSim didn't accept defparam in mixed language projects, so that I needed to change existing code.
FvM
Super Moderator
Staff member
Bochum, Germany
Thanks! In fact defparam is still supported in Modelsim, which is necessary at least as a legacy measure. But for some reason, not in mixed language designs, when instantiating VHDL components in Verilog text.
eng.amr2009
Egypt
Thanks people, it really works for Xilinx ISE. Still have problems with modelsim !
Is there any workarounds for modelsim mixed language projects ?
I'm still not much experienced in verilog, I used only VHDL for 3 years.
Thanks in advance
FvM
Super Moderator
Staff member
Bochum, Germany
Does your Modelsim license include mixed language simulation?
ads_ee
Full Member level 6
San Diego
yes the #() works in modelsim. I've been using this syntax over many modelsim versions: 6.6e (may be an even earlier version, but that's the oldest I have installed) up to 10.1b.
Have you tried a simple test case? Something like a VHDL register with a generic width and instantiate it in a Verilog top level?
-alan
