how to install dictionary in ubuntu 11.10
If you want to use complete Dictionary offline simply install dictionary by following commands. Open terminal (Alt+F2 and type: terminal-gnome) and copy the following commands in the terminal:
sudo apt-get install dictd
sudo apt-get install dict-gcide
sudo apt-get install dict-moby-thesaurus
After installing the Dictionary you have to do the following settings in the dictionary:
Open Dictionary and go to Preferences, Click the "Add" button to add a new dictionary.
Now Enter the following details.
Description: Local Server
Transport: Dictionary Server
Hostname: 127.0.0.1
Port: 2628
Then click on add button. Then Edit => Preferences select Local server.
That's it.
take software centre in ubuntu 11.10
in search option type Dictionary (you will get a lot softwares list)
install the required dictionary by reading the review.
it is as simple as that.....
i like golden Dictionary.
If you want to install it, you can open the terminal (Cntrl+Alt+T), then type:
sudo apt-get install goldendict
or do it from the software centre as I mentioned above...;-)
As yura717 said installing those packages can be a + to a dictionary like Golden Dict.
all the best
Hi Yura
I installed it using commands given by you, but i cant find where it is installed..
thank you!
---------- Post added at 14:45 ---------- Previous post was at 14:40 ----------
Hi rjkrocks, I tried to install golden dict using software center
I found it but the install butten is not highlighted in it.
it shows no network connections though I have connected to internet using my docomo 3g stick.
Thank you!
Thank you!
Have you tried using the command line as i mentioned,
even if you are getting the error.....
Disconnect the internet.. restart ububuntu.. reconnect and try. If you can acces other programs. then you will be able to use it. All the best
You can find the dictionary here (Applications => Office => Dictionary)
  • Screenshot at 2011-12-25 22:43:03.png
it is installed by using command, thank you!..
but why the install button in software center is not highlighted?
Most probably it is because of some temporary communication error.....
or the software centre may take some more time.......
or during that time internet was not connected.....
or some other program may be using all the bandwidth available
or Some other program installing. (this won't usually give problems.... but chances are there)
